copier direct to computer Ping response time
  • aviso66
    • Dec 2012
    • 202
    [Misc] copier direct to computer Ping response time
    Hi I just want to clarify when i connect directly to the copier from my laptop using network cable. Then i do a ping to get response time.
    and i get a reply with
    .............bytes=32 time <1ms ttl=225
    .............bytes=32 time =1ms ttl=225
    does this means there's unstable connection when there's = and <?
    • 37529
    Re: copier direct to computer Ping response time
    NO. Now if there were occasional times in excess of oh lets say 100ms then there could be a problem or one of the devices is occasionally busy with some other background function.
      • 23009
      Yep, that's exactly what we hope for: < 1 millisecond is perfect. =^..^=
      • aviso66
        • Dec 2012
        • 202
        does it tell if the controller board has malfunction through pinging the machine?
          • 37529
          NO. On most controller boards the ping response is handled by with chip that connects directly to the jack.
          • 8T2
            • Aug 2015
            • 257
            Why do you suspect a controller malfunction?
            Sent from my SM-A305F using Tapatalk
              • 37529
              If there is one, pinging will most likely not find it. It only tests the network jack, the modem chip that the jack connects to and the communication control chip that controls the modem, i.e tells it to respond if the IP address in the ping is correct. It does not detect any of the date channels out of the communications control chip. I had open once where ping worked, WIM could be accessed, scan to folder and scan to email all worked but the print channel did not.
              • tsbservice
                Field tech
                • 8020
                ... I had open once where ping worked, WIM could be accessed, scan to folder and scan to email all worked but the print channel did not.
                That sounds pretty nasty slim. I guess troubleshooting then was nightmare.
                  • 37529
                  Had to replace the controller.
                  • tsbservice
                    Field tech
                    • 8020
                    That's for sure. We have some Toshy back in the days where NIC was separated board like on older PCs.
                    Much cheaper than whole new main board. Not today 😂
                      • 37529
                      Some really early Ricoh digital models were the same.
                      • KenB
                        Geek Extraordinaire
                        • Dec 2007
                        • 3944
                        Yep, Canon used to be the same way.
                        Nothing like needing to replace a $3,000 main controller because of a flakey $10 NIC.
                        Not to mention trying to explain that to a customer without a service contract.
