Can print but cannot scan
  • KeviM
    • Oct 2019
    • 324
    Re: Can print but cannot scan
    Also remember to select a username before scanning.
    1 more thing : try this
    Place an original on the platen glass and scan to an email address. Don't forget to press hash when done
    Let me know if that works ( after you put in the settings)
    • sgapt
      • Jun 2022
      • 9
      Do the following:
      1. Attempt to test SMTP connection from the front panel
      2. As soon as it fails, go to Interface settings and print the settings, button at the top of the tab.
      3. The last page will be a communication log and should have at least one line reporting what had happened when you tested the SMTP connection
      That will tell you what the internet error and if you are being blocked by the router/gateway/modem. Easier to use than Wireshark.
      Thanks, SMTP connection passed. in fact all connection tests passed and ping was successful.
        • 37345
        Originally posted by Zaxxon
        If you are a enduser, my advice is to call a tech, as this forum is for service engineers not endusers.
        Not necessarily so. Right now there are 77 members and 2,973 guests. Most likely at least half of those guests are end users looking for a solution to their problem.
          • 37345
          #19
          Then the next step is to try sending something.
          • sgapt
            • Jun 2022
            • 9
            #20
            the problem is the machine won't let me send, the start button would not turn green despite all connections passed and destination selected.
            • Elmo
              • Feb 2010
              • 541
              #21
              Have you tested it on a wired connection
              Also have you set a default sender
              I Used To Live To Fix Things Now i Fix Things To Live
              • luca72
                • Oct 2017
                • 1740
                #22
                seem that the machine dont feel the original(?)...you can hear the beep sound when you put in the sheet in to rdf tray?
                  • 37345
                  #23
                  That will happen if, as Elmo mentioned, you have not set a default sender and do not select a send, or maybe you do not even have senders designated in the address book.
                  • emiliorsg
                    • Jul 2018
                    • 141
                    #24
                    System settings / file transfer / administrator e-mail address. Enter the email address you sent.
                    System settings / file transfer / specify auto sender / enabled
                      • 37345
                      #25
                      For best results, the administrator e-mail address should be the same as the authentication address or at least the same domain, @"domain.com" where domain is the company's email domain.
                      • KeviM
                        • Oct 2019
                        • 324
                        #26
                        Have you tried this?
                        It could be the sensor which detects if the document feeder is open or closed is damaged
                        Also make sure to set a senders name
                        • sgapt
                          • Jun 2022
                          • 9
                          #27
                          Sensor checked and working, default sender selected, administrator email used to be a ricoh email address and I tried changing it to my domain email, both didn't work.
                          • sgapt
                            • Jun 2022
                            • 9
                            #28
                            Thanks, default sender selected, send target also selected, have also checked the address book details.
                            • sgapt
                              • Jun 2022
                              • 9
                              #29
                              Thanks to all for responding to my thread, especially KeviM, slimslob and luca72! Although no one response resulted in the resolution of the issue, they all pointed me to the final resolution! With all the input (more importantly, your replies keep me going), I have managed to resolve the issue.
                              I changed the administrator's email address back to the ricoh's email address. It did not resolve the issue immediately.
                              Next, I powered down the machine for a few minutes and powered on again. This time, the start button turned green once destination was selected.
                              I tried scanning but it still did not work, showing "Authentication with the destination has failed. Check settings. To check the current status, press [Scanned Files Status]."
                              I changed the SMTP authentication user and email address back to the old email used before the shift. Finally, the scanner sent out the email successfully. For some reason, the new email did not work despite the correct password. I suspect Ricoh prevented the changes to the user and administrator emails even though i have the administrator rights to make changes.
                              Thanks once again for not giving up on this end-user!
                              • rthonpm
                                • Aug 2007
                                • 2848
                                #30
                                Depending on your mail provider, the account you used may not have permission to use SMTP authentication.
                                Who is your email provider?
                                Onsite/internal email
                                ISP
                                Micosoft 365
                                GSuite
                                Sent from my BlackBerry using Tapatalk
