C306Z hardware upgrade?
  • lurker1652
    • Mar 2021
    • 58
    #16
    Re: C306Z hardware upgrade?
    Originally posted by luca72
    look! if you want boost your ricoh mf, at zero cost, you can disable the java enviroment from user tools>exension feature>auto start>[deselect java]...this in particular increases the startup speed
    for the rest...i suggest that is born like this, dies so...LOL...i think that if ricoh in 2022 use a mechanical hdd, probabily there is a reason
    Thanks, would that be through WIM or SP mode?
      • 37491
      #17
      Control Panel.
