C306Z hardware upgrade?
  • lurker1652
    • Mar 2021
    • 58
    I have a Ricoh c306z, which seems to work but trying to upgrade firmware lately with the Ricoh Upgrade Tool it locks up and I have to power cycle it.
    This reminds me of PCs acting up when memory modules are damaged and I wonder if there's a memory test function to confirm the memory module is healthy.
    Also, I wonder if changing the module for a bigger one and swapping the hard drive for an SSD would make it any snappier. Any experience in that regard?, are memory and disk upgrades any good?
  • copier tech
    • 8192
    Re: C306Z hardware upgrade?
    This remind me of PCs acting up when memory modules are damaged and I wonder if there's a memory test function to confirm the memory modules is healthy.
    The best & safest way to update the firmware is VIA the SD card method. The tool is very unreliable on many models & some users have ended up needing to replace the controller board after using the update tool after it fails half way through the process.
    • UNICORNico
      • May 2018
      • 308
      Currently it is in a trial period, but I have in 2 or 3 machines where the HDD, was replaced by an SSD because they were cheaper. And so far we have not noticed problems, the only difference has been that the device seems to boot the systems somewhat faster.
      "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
      • lurker1652
        • Mar 2021
        • 58
        Good to know. What about memory?:
        1. Is there a memory test function?
        2. Is there a second channel to add another module?
        3. If not additional module, would it add any value going with a module bigger than 2GB?
        • lurker1652
          • Mar 2021
          • 58
          Regarding the update, that would be my next step. The tool downloads and keeps the firmware files, so I will try with SD upgrade.
          Just wanted to make sure memory module/s are healthy.
          • UNICORNico
            • May 2018
            • 308
            The problem with RAM is that we do not know the specifications of the speed BUS at which these memories must work in the controller.
            533mhz or 1333mhz? If you do the test there is a risk that you will not recognize the RAM by the frequency. And to place one of more capacity, it is unknown what is the maximum that tolerates.
            By how they are physically we can intuit that they are DDR2 or DDR3 in some cases, and according to what I look at most are Samsung chip, but the PCB belongs to RICOH itself.
            Regarding the subject of testing, if I can tell you that at least in my experience and used RAM modules of copiers / printers in laptops and have worked, it will be a way to make a Memtest (one of the best programs for RAM testing).
              • 37556
              The files that the tools downloads are not SD card firmware. They are either package firmware or remote firmware. Remote firmware files can be installed using WIM.
              • Gift
                • Mar 2011
                • 2459
                I don't see the RAM as any potential bottleneck for a MPC306.
                • UNICORNico
                  • May 2018
                  • 308
                  After many years, I have the theory that Ricoh mainly uses HDDs as Virtual Memory, instead of using RAM for said processes, being faster. This may be due to how the Operating System (or its kernel) is designed on machines. In fact, it reminds me a lot of how some somewhat older versions of Linux worked, forcing the generation of a specific partition to Virtualize Memory.
                  • luca72
                    • Oct 2017
                    • 1791
                    look! if you want boost your ricoh mf, at zero cost, you can disable the java enviroment from user tools>exension feature>auto start>[deselect java]
                    for the rest...i suggest that is born unsteady, and dies so...LOL...i think that if ricoh in 2022 use a mechanical hdd, probabily there is a reason
                    "I'll be back"
                    • luca72
                      • Oct 2017
                      • 1791
                      look! if you want boost your ricoh mf, at zero cost, you can disable the java enviroment from user tools>exension feature>auto start>[deselect java]...this in particular increases the startup speed
                      for the rest...i suggest that is born like this, dies so...LOL...i think that if ricoh in 2022 use a mechanical hdd, probabily there is a reason
                      "I'll be back"
                        • 37556
                        Considering that both Ricoh's core OS and Linux are both derivatives of Unix I would say that you are correct. THe formatting that a Ricoh does to a HDD is merely just the allocating of those "partitions" one of which is the printer spool.
                          • 37556
                          I agree. Unless the customer has a JAVA based app that they absolutely have to use, there is no reason for having JAVA, other than to allow sales personnel to say they have it. On many models you cannot get into SP menus or User Tools other than the Counter until JAVA has finished initializing. On some machines that can be 5 minutes or more.
                          • luca72
                            • Oct 2017
                            • 1791
                            Infact! I hate that very long time to access sp's
                            "I'll be back"
                            • KenB
                              Geek Extraordinaire
                              • Dec 2007
                              • 3944
                              I’ve seen machines throw SC errors that were caused by corrupted Java, even when Java wasn’t being used.
                              As Slim said, disable it if it isn’t needed by an add-on app.
                              Here’s a tip, though. If Java is on an SD card, simply disable it, and don’t remove the card.
                              If the card gets removed, it will inevitably get misplaced, and then next thing you know the customer gets an app that requires it. In addition, in most situations, the customer paid extra for the option.
                              Some models had it included at the factory for some length of time, but those days are gone. In fact, even though the option is still in the price book, it is no longer available for some if not most models (which is an entirely separate sore subject).
