Ricoh C307 Reduce paper in tray(s) to limit mark or reset it properly
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1250
    Tray sensor flag appears to be in the proper position but tray cannot be used due to the Reduce paper in tray(s) to limit mark or reset it properly message.
  • UNICORNico
    • May 2018
    • 308
    Re: Ricoh C307 Reduce paper in tray(s) to limit mark or reset it properly
    Does the paper detection failure give you in the 1st tray, or is it an auxiliary tray? Is it in all trays?
    "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
    • blazebusiness
      • 1250
      Unit only has cassette 1 and bypass. The issue is with cassette 1. Also had a previous 501-00 code. I'm thinking it must be the D2052526 Paper Detector or less likely it could be the TRAY LIFT SENSOR or maybe the BASE RISE ASS'Y
        • 37488
        Most likely the tray lift sensor is being detected before the paper detector. Either a bad sensor or I have had a warped lift pan do the same.
        • blazebusiness
          • 1250
          Makes sense, I'll probably replace both sensors then, thanks for responding.
          • ridgemill
            • Sep 2017
            • 190
            We've had a few of the raising levers crack and break over the years.
