Light prints on MP C3003
  • menosmola
    • Apr 2014
    • 95
    Hi, i have a customer that insist that the prints come out too much lights. The machine has few copies, original toner, new pcu, new fuser, new transfer unit... this client has regular eyesight.... how could i darken the prints? I do not know what else to do. Any idea what i can do?
  • DRichard
    • May 2008
    • 482
    Re: Light prints on MP C3003
    Try better quality copy paper? Make sure the end-user understands the limitations of this machine. They have to understand this copier/printer will NEVER equal what a production level color copier or inkjet printer might provide them.
    "Enjoy every sandwich."
    -- Warren Zevon
    • Gift
      • Mar 2011
      • 2459
      color copy paper usually improves the solids and general image quality a lot.
      In case the dev units hasn't been replaced it's possible that the density faded over time. If yo clean the PM parts and ID/MUSIC sensors it's usually no problem to run some "force toner " cycles and re-initialize the dev via SP. Of course these suggestions are only to perform if the outputs really show a lack of density/full solids - if the machine seems OK you shouldn't try overtoning it. Perhaps you can print some comparisons with another MPC3003 to prove that your customers MPC is working like it should.
      • mikadonovan
        • May 2008
        • 2931
        Clean ID sensors and run ACC before doing anything else.
        NEVER ASSUME ANYTHING
          • 37532
          I have had just cleaning the optics correct the problem as long as previous ACC settings were still in memory. At one time Ricoh-USA had an information bulletin instruction techs to run ACC after any firmware update.
          • sandmanmac
            • 3981
            You say that "the customer says copies are light....."
            We don't really give a Sh*t what the customer says to you.
            What do you say? Is the image actually light?
            Let's see a colour test page sample......
            • menosmola
              • Apr 2014
              • 95
              I say that the quality of the prints is perfect...
              • menosmola
                • Apr 2014
                • 95
                Ok, I have solved the problem by changing the PCL6 driver settings, i have removed all the brightness, only in the text option and it seems that the client is satisfied...
                • DRichard
                  • May 2008
                  • 482
                  You are the tech. If this is the case, that should be good enough and I refer you to my prior post. It is not always easy to deal with customers with unreasonable expectations.
                  -- Warren Zevon
                  • menosmola
                    • Apr 2014
                    • 95
                    Well, the client has vision problems, so I have done what I could, he has been happy, so all is well that ends well.
                    • MIGUELMARCHENA
                      • Feb 2018
                      • 195
                      yes it made me laugh
                      • Gift
                        • Mar 2011
                        • 2459
                        As a general information I'd like to add that some "punches of the back of ones head" can both cause and cure vision problems
