Slow faxing and memory full Ricoh MP C6004
  • ABS tect
    • Sep 2013
    • 511
    Ricoh MP C6004
    I have a medical office that is being audited and the recipient is requiring individual packets of 30 pages each to be sent and they HAVE to be through fax.
    They are saying it is taking 20 minutes for a fax of 30 pages to go through. So they did 5 faxes, totalling 150 pages, and the memory is full on the fax and they can't send anything else until it goes through.
    They have to do 40 packets by a deadline and have hardly gotten through 5.
    I know very little about fax units, is this normal speed for a fax? Is it the machines issue (storage capacity), customer's phone line, recipients phone line?
    I'm not sure where to start on this one. Thanks.
  • KenB
    Geek Extraordinaire
    • Dec 2007
    • 3945
    Re: Slow faxing and memory full Ricoh MP C6004
    What resolution are they being sent at?
    High resolution can dramatically increase storage size and sending time, especially on halftone images.
    • ABS tect
      • Sep 2013
      • 511
      Standard
        • 36745
        Originally posted by ABS tect
        Standard
        But what is the standard set to?
        • KenB
          Geek Extraordinaire
          • Dec 2007
          • 3945
          Are there images, shading, noise, a lot of fine text?
          These are all things which make for increased send times, as well.
          This is all before bad line conditions come into play.
            • 36745
            Sounds like they need an email to fax service such as eFax. Fax Online | eFax
            If they have the documents on the HIS they can just compose the emails on their computer or for hard copy documents they can scan to email. To the recipients document packets are received as faxes with a reply fax number. Replies sent to that number are received as email attachments. A couple of other senior NCO and I used them when we were in Iraq in 2005.
              • 36745
              Then there is slow downs at the destination. ABS tect customer is most likely not the only medical office being audited.
                • 29349
                Ricoh MP C6004
                Pretty standard the speed is based on the other fax and line. 30 pages and 20 min sounds right.
                They need to send by email or print and mail them. It will take hours to send all there faxes.
                good luck
                • KenB
                  Geek Extraordinaire
                  • Dec 2007
                  • 3945
                  good luck
                  • csliao
                    • Oct 2021
                    • 33
                    Ricoh MP C6004I have a medical office that is being audited and the recipient is requiring individual packets of 30 pages each to be sent and they HAVE to be through fax.They are saying it is taking 20 minutes for a fax of 30 pages to go through. So they did 5 faxes, totalling 150 pages, and the memory is full on the fax and they can't send anything else until it goes through.They have to do 40 packets by a deadline and have hardly gotten through 5.I know very little about fax units, is this normal speed for a fax? Is it the machines issue (storage capacity), customer's phone line, recipients phone line?I'm not sure where to start on this one. Thanks.
                    Q: FAX modemspeed is
                      • 36745
                      Originally posted by csliao
                      you need email not FAX
                      Apparently you did not read "they HAVE to be through fax."
                        • 29349
                        Really nothing has to be faxed
                        This is were a good Tech explains why its taking so long and give them options to achieve the same goals.
                        email
                        flash drive
                        print and mail
                          • 36745
                          email
                          flash drive
                          print and mail
                          When an audit team says they want things sent to them by fax, they will not accept anything sent any other way.
                            • 29349
                            BS its 2022 nothing has to faxed
                            Lots of other options available
                            Fax is a slow go at 30 pages
                            email
                            flash drive
                            print and mailI
                            It would take 14 hours to send all the faxes.
                              email
                              flash drive
                              print and mail
                              You should call the manufacturers and tell them to stop making the fax option for their machines. Get on it.
