Ricoh 3003 toner not combing to form 1 item
  • Bildad
    • Jul 2022
    • 3
    Hi i have ricoh mpc 3003,when i print a photo,i receive 4 photo,1 in cyan, 1 in black, 1 in magenta and 1 in yellow.the 4 toner print each as single item..then before printing it produce a pop sound.i need help to fix it
    • 37478
    Re: Ricoh 3003 toner not combing to form 1 item
    Sounds more like a corrupted driver than the C3003 itself. May also be a corrupted firmware or printer memory.
    • DRichard
      • May 2008
      • 482
      Yup. Definitely not a mechanical issue...the "POP" sound at the end is just a bonus.
      "Enjoy every sandwich."
      -- Warren Zevon
      • sandmanmac
        • 3981
        So it's ONLY when PRINTING photos?
        What happens when you make a colour copy?
        What happens when printing other types documents in colour?
        Your OBVIOUSLY not a tech, but most of us aren't psychics either
        C'Mon man.
        • Bildad
          • Jul 2022
          • 3
          Even when i print a statement,it bring 4 statement,1 in yellow,1 in cyan, 1 in black and 1 in magenta
          • tsbservice
            Field tech
            • 8007
            Clearly your drivers are setup incorrect. Remove them and reinstall.
            • Tedstryker73
              • Jun 2019
              • 5
              I would make sure you are using a Ricoh print driver, and not a generic driver. Also, make sure it isn't set up with a WSD port, which will cause all kinds of problems. Usually the PCL6 is the most stable choice. If you are already using a Ricoh print driver, then doing a memory clear for the print application would be my next step.
                • 37478
                You are going to have to provide a hell of a lot more information.
                1. What type of computer are you using
                2. What version is the OS on that computer
                3. What is the software that you are printing from
                4. What print driver is the computer using, include version number
                5. What port are you printing through
                6. How long have you had the C3003
                7. When did the problem start
                8. What are the versions of all the firmware on the C3003
                Like Sandy said, we are not psychics.
                • luca72
                  • Oct 2017
                  • 1774
                  maybe i dont understand well(?)...you print 1 color sheet, and the machine out 4 sheet with same image, but each with a single color?
                  if you make a single copy color, or SP print color test, what happen? you have a postscript sd installed? ....this happen from all pc's?..if this, try a system printer reset with SP 801 (printer)
                  "I'll be back"
                  • luca72
                    • Oct 2017
                    • 1774
                    .... indeed, looking back on it, it also smells a bit of an engine (?) .... since it doesn't jam .... at least, so I understand(?)
                    "I'll be back"
                    • Gift
                      • Mar 2011
                      • 2459
                      I have no idea what the thread starter tries to describe - perhaps it's just color shifting. I guess things got lost during translation...
                      A video might be helpful to isolate the problem beyond random guesswork....
                      • davel
                        • Oct 2011
                        • 1103
                        Are you saying when you print 1 copy it gives you 4 sheets of paper? Is the full image on each sheet or only the separate colour parts of the original image? Sounds like driver to me.
                        • DRichard
                          • May 2008
                          • 482
                          ...or maybe a translation issue?
                          -- Warren Zevon
                          • UNICORNico
                            • May 2018
                            • 308
                            I think this is the perfect thread to make a bet (do we play a game?, let's make a lottery), let's see which of us has better telepathic, divinatory or powers over this event xD lol.
                            The one who comes closest to the correct answer, will receive from the one who started the thread, a like to all his posts for 1 month.
                            "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
                            • Gift
                              • Mar 2011
                              • 2459
                              Seems the thread starter found his closure on this topic - last post was 5 days ago.
