RICOH MPC3003 whitish stuff on color pattern and printouts
  • Pixtech Frameworks
    • May 2020
    • 238
    Hi All,
    I trust everyone's fine. A customer called my attention today concerning this white stuffs that appears on printouts, and I did color pattern and found out something was wrong somewhere, I've swapped transfer belt film and do some thorough cleaning still the same, this is my first time to encounter this problem. Does anyone what could be the problem? Attached is a sample of the color pattern.
    • 37532
    Re: RICOH MPC3003 whitish stuff on color pattern and printouts
    You have a repeating pattern. If the bottom of the paper is the leading edge, I would say the fusing unit.
    • tsbservice
      Field tech
      • 8020
      Absolutely. OP do some maths and measure the distance you will find what's roller diameter.
        • May 2020
        • 238
        Funny enough, when u print black it doesn't up on it, except color
          • May 2020
          • 238
          Not fuser unit slimslob. Another unit was inserted on the machine, it was still the same.
          • rthonpm
            • Aug 2007
            • 2859
            How do the colour PCU's look? Genuine toner?
            Sent from my Pixel 6 Pro using Tapatalk
            • Gift
              • Mar 2011
              • 2459
              My first thought: I'd also say fuser unit .........................but on the other hand the missing toner should be visible as "offset"
              That "Genuine toner?" question is a good one - I'd also try and interrupt the print process wile printing full bleed test samples and check the components.
              Edit: Perhaps it's an issue with the transfer roller/transfer on paper process - in this case a lot of residue of the image would remain on the upper side of the ITB
              • emiliorsg
                • Jul 2018
                • 141
                I think it is caused by the paper transfer roller, look at the distance between the repetition of the fault and the diameter of the diferent rollers in the MFP.
                • UNICORNico
                  • May 2018
                  • 308
                  Excessive moisture in the paper could also lead to similar defects in the transfer.
                  Have you tried using new paper? I usually carry a pack of folios inside a bag with closure and several desiccant bags, which are sometimes in shoeboxes or when new machines are installed.
                  "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
                  • luca72
                    • Oct 2017
                    • 1784
                    Originally posted by Pixtech Frameworks
                    Hi All,
                    in base at the distance, seem a humidity condensation or grease/oil stains on one of the four opc drum surface.
                    "I'll be back"
                    • emiliorsg
                      • Jul 2018
                      • 141
                      From what you see in the test pattern, at least the problem appears in cyan and magenta, so it seems more of a transfer or fuser problem.
                        • 37532
                        Not when type and thickness are wrong.
                        • fbkhan3
                          • May 2012
                          • 421
                          Hi All,
                          Try changing the paper thickness ,as thick 1 or Thick 2 and see if that makes any difference,If it gets better than you have issue with Paper itself or Toner being the issue.
                          Regard's
                            • May 2020
                            • 238
                            Genuine toner.
                              • May 2020
                              • 238
                              Paper transfer had been swapped, still the same.
