RICOH MPC3003 whitish stuff on color pattern and printouts
  • Pixtech Frameworks
    • May 2020
    • 238
    Re: RICOH MPC3003 whitish stuff on color pattern and printouts
    Originally posted by emiliorsg
    From what you see in the test pattern, at least the problem appears in cyan and magenta, so it seems more of a transfer or fuser problem.
    I've checked fuser, no issues.
    • Gift
      • Mar 2011
      • 2459
      Not when type and thickness are wrong.
      Wasn't aware this fuser has a cleaning roller for picking up the residue.
      @Pixtech Framework:
      I still think it's a paper transfer issue - perhaps a bad ground/contact to the paper transfer roller. It's easy to check if you interrupt the print process and check out the image on the upper side of the ITB - I bet there's more to see than usual.....
        • May 2020
        • 238
        I have found the solution, it took me time to find out that some gears we're worn out and was causing interruption also found out one ITB internal rollers was the major culprit (spring wasnt ok) I had to transfer ITB sleeve to an abandoned carcass and machine was back and it's running fine now.
        Thank you all for your various contributions. Gracias.
