MP C307 primary tray setting
  • mikadonovan
    • May 2008
    • 2931
    Hi, All. I have a C307 with a second tray (500 sheet) added. It feeds fine from it, and I have it set in system settings to be the primary (default tray). However, copying and printing it is still defaulting to tray 1. Paper types and weight are identical in both trays. Why oh why is that happening?
    NEVER ASSUME ANYTHING
    • 37533
    Re: MP C307 primary tray setting
    I could see it with printing if the driver or document specifies Tray 1 as the default.
    • sandmanmac
      • 3981
      Interesting Mika.
      Can I ask why you want tray 2 to be the default? I'm assuming that they want to use a special paper or letterhead in tray 1?
      Weirdly, It does appear that you can't just set tray 2 as the default for copying (even though it appears you can), so if I'm correct, the easiest solution would be to set the paper type for tray 1 in tray paper settings to "Letterhead" (or whatever you like). This will force Tray 2 the default tray and nothing will come out of tray 1 unless the specific paper type setting is selected in their printing preferences when they want to PRINT from it, or manually selecting it when copying.
      Hope this helps
        • 37533
        Originally posted by sandmanmac
        Interesting Mika.
        Hope this helps
        It might be due to the fact that tray 1 only holds 250 sheets whereas the paper banks hold 500 sheets.
        • sandmanmac
          • 3981
          Could be. We'll see what Mika says.
          The machine will automatically go to tray 2 if tray 1 runs out, so I'm not sure why just simple tray capacity would matter -although as we know some customers can just be real PIA's
            • 37533
            Could be the fact that 500 sheets is a full package of paper.
            • Gift
              • Mar 2011
              • 2459
              Shouldn't be a big deal - check if "auto paper select" isn't disabled for tray 2 (or, as a workaround, just disable it for tray 1 in the paper type setting for tray 1).
              Also make shure that auto paper select is the default setting in copy mode and in printer driver setting.
              • mikadonovan
                • May 2008
                • 2931
                Thanks for all the replies. I went ahead and selected tray 2 on the copy screen and programmed that screen as default, then instructed the client to set tray 2 as default in their driver preferences. That's working for now. The real matter in this particular clusterfuck is that they went from a c5502 to a c307 which they hate. Smaller, slower, tray 1 capacity is 50% less, and so on.
                • dalewb74
                  • Feb 2018
                  • 1157
                  dont you just love cheap customers and then they complain about what they paid for? lol
                  • KenB
                    Geek Extraordinaire
                    • Dec 2007
                    • 3944
                      • 37533
                      Originally posted by KenB
                      It’s like going from a Corvette to a Cavalier.
                      What, they’re both Chevies!
                      I'd say more like going from a Leer jet to a Piper Cub.
