ricoh pro c7100sx
  • chughtai
    • Sep 2021
    • 25
    [Misc] ricoh pro c7100sx
    hi dear,s
    ricoh pro c7100sx giving problem for yellow color over printing (its mean hole page light yellow)
    first i did clean all inside drum unit and transfer belt in transfer roller but problem still same. then i swap drum and charger to cyan color but still same
    cyan color is good but yellow still over print i did also developer refresh yellow but i not solve issu.
    if any one have idea help for solving this issu.
    thanks.
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: ricoh pro c7100sx
    What sort of mileage do the devs have on them?
    Hit it.
    • kevslane
      • Mar 2017
      • 24
      Try fitting a potential sensor D0143655
      Sent from my SM-A526B using Tapatalk
      • anothertech
        • 1769
        That's a big job, plan on being there for awhile.
        • kevslane
          • Mar 2017
          • 24
          If you take the Y and M PCDU's out and pull the ITB out fully on the rails, you can change it without going through the top.
          • bojans
            • 1313
            First you should do ProCon and check for the errors. I also believe its a potential sensor. If you have skills and not too big hands, its possible to change it when you pull out PCDU.
              • 37488
              Considering that laser technology uses write to no charge, you may have a damages charge connection for the Y PCU. It could even be a bad HVPS.
              • UNICORNico
                • May 2018
                • 308
                Could you post images of the ruling? It would be more illustrative than the words
                "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
