IM2500 J001 and J012
  • Keegan Chetty
    • May 2015
    • 113
    Hi all
    Please could I have some assistance, I have an IM2500 that shows J001 and J012, every page jams and the machine only has 24k on the clock.
    I've tested input and output on the following and it works perfectly, reg sensor, transport sensor 1 and 2,drum and dev motor, reg motor and fusing motors.
    If I bypass the door and run output check on the reg motor and feed a page through manually it goes into the fuser but if you try to make a copy or print, it just stops at registration, I have also replaced the bcu board with a brand new one but it still does the same thing, I've tried a side door but unfortunately I wasn't able to test the door before trying it on.
    I've attached some pics, thanks for the assistance. Screenshot_20220815_131045_com.android.gallery3d_edit_132853457859415.jpgScreenshot_20220815_131049_com.android.gallery3d_edit_132840118309938.jpg
  • Keegan Chetty
    • May 2015
    • 113
    Re: IM2500 J001 and J012
    update: I have changed the feed stations and reg sensor and motor, still makes no difference, I have ruled out the feed stations since it does this even through the bypass tray.
    • KeviM
      • Oct 2019
      • 324
      I had a similar sort of problem with a different machine. What had happened was the actuator for the sensor was "shortened" by the paper rubbing over it. Kinda like a sandpaper effect on it.
      Try replacing the actuator and test.
      Also spray a bit of Q20 / lubricating spray on the points where the actuator hinges and swivels
      Best of luck friend
      • fbkhan3
        • May 2012
        • 421
        have you checked the transfer roller if it is positioned right?
        have you tried printing SEF?
        Regard's
        • Brianneoe
          • May 2015
          • 318
          There is a bulletin going back to 2019 about the exit unit screws not installed correctly causing exit jams. The solution was to replace the exit unit. D0BQ4404
          • Keegan Chetty
            • May 2015
            • 113
            Hi Friends,
            Update: you will never guess it, the previous tech that went out replaced the tray 1 feed motor with a tray 2 feed motor which was causing these issues! Once I replaced the feed motor with a tray 1 motor everything worked perfectly. Thanks all
            • TonerMunkeh
              Professional Moron
              • 3865
              Obvious question is - what the hell's the difference?
              Hit it.
              • Keegan Chetty
                • May 2015
                • 113
                Exactly, I didn't think there would be until I noticed while looking at another machine that one had a sticker on the back and the other did not, then I looked at my machine and both had stickers on them (those stickers with the part numbers), I just decided to replace the motor thinking nothing would change but it worked from the first copy, not only that, the first, second and bypass all refused to work when the incorrect motor was in, once I changed it, everything worked perfectly.
