Scanning with OCR
  • GeorgeBest
    • Jul 2009
    • 526
    Scanning with OCR
    Hi,
    Installed an OCR unit on a MPC3004, now when scanning in OCR mode, and making a PDF document for example 20pages, some of those pages are turned in the document and shows as A4R (!!)
    Strange, because I configured the scanformat in default A4 (fixed)
    Even stranger . . . when I scan the same PDF document DISABBLING the OCR temporary all pages shows A4
    Can't see any adjustments within the settings of the OCR for fixing this problem . . .
    anyone?
    Thanks in advance
    • 37532
    Re: Scanning with OCR
    I believe that in order for the OCR function to scan for readable text the page has to oriented in a readable direction. One of the drawbacks to installing OCR.
    • copier tech
      • 8172
      Originally posted by GeorgeBest
      Hi,
      anyone?
      Thanks in advance
      How about if you feed in A4R does it convert some to A4 ?
      Also it's worth updating the firmware this will also update OCR & may resolve the issue.
