I am working on Ricoh 3045 with SC322. I noticed copier function and scan feature are working fine. Only when you try to print or machine try to print out fax confirmation, it show a red wrench SC322.
Ricoh Aficio 3045 SC322
The machine copies at 400 dpi and prints at 600 dpi (including internal prints) so your 600 dpi pitch is most likely out of spec.
Do the LD beam pitch adjustments. If that fails you may need to remove and clean the laser unit or replace it. You'll find the proceedure in the Replacement and Adjustment/Laser Unit section of the SM.sigpic
Relax! This firmware injection won't hurt...but it will take 45 minutes.
