How to Install the send Meter App on Ricoh Copiers SOP
  • Aplustechnologies
    • Aug 2022
    • 3
    Good Morning
    Need help on How to Install the send Meter App on Ricoh Copiers SOP.
    Thank you in advance
    • 37487
    Re: How to Install the send Meter App on Ricoh Copiers SOP
    SOP Designer tool
    • Aplustechnologies
      • Aug 2022
      • 3
      I was able to install the send meter app with the SOP designer Tool, and I configure it and everything seems fine, but when try to use it it fails, and says authentication error... And I have an Office 365 SMTP that is working fine with the scan to email function on that machine... Maybe I'm missing something...
      • UNICORNico
        • May 2018
        • 308
        If I remember correctly, both Microsoft and Google changed their security policies with authentication services.
        Does the account you use for the Office 365 service use 2-step verification? Maybe that's the problem. You'll need to create a specific key for "device validation." Review your Microsoft account settings.
        "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
        • Aplustechnologies
          • Aug 2022
          • 3
          Thank you for your reply.
          I don't have the 2 steps verification... and on the sender email I'm using the the same as SMTP used on scan to email function that is working fine on the machine...
          • Batman1976
            • Jun 2016
            • 91
            I have had similar issues with send meter app failing using Office365 lately, Any Update on this would be gratefully received?
            • rthonpm
              • Aug 2007
              • 2853
              Make sure that SMTP Auth is enabled on the sending account. While Microsoft is enabling multifactor authentication for access to mail accounts, SMTP authentication is exempt from that requirement.
              Enable or disable SMTP AUTH in Exchange Online | Microsoft Docs
              Sent from my Pixel 6 Pro using Tapatalk
