Disable auto power off mpc300
  • pakobernal
    • May 2012
    • 46
    Greetings from Spain, I have a small problem with an mpc300, when it goes into auto power off mode it doesn't print.
    My question is, is there a way to disable auto power off with some smc? In settings only let it go from 1 to 60 minutes.
    Thanks.
  • DRichard
    • May 2008
    • 482
    Re: Disable auto power off mpc300
    Thanks.
    From Service Bulletin:
    SUBJECT: CANNOT RECOVER FROM ENERGY SAVER MODE
    SYMPTOM:
    The machine cannot recover from Energy Saver mode after the Power Saving System firmware has been
    updated to version F.14 (M0265773B).
    CAUSE:
    There is a bug with Power Saving System version F14 firmware.
    SOLUTION:
    Update the Power Saving System firmware to version F.15 or newer.
    Temporary Solution:
    If you cannot update to version F.15 (and version F.13 or F.14 is installed), update the System/Copy
    firmware to version 1.04 (P/N M0265771F). This will also correct the symptom.
    "Enjoy every sandwich."
    -- Warren Zevon
    • pakobernal
      • May 2012
      • 46
      SYMPTOM:
      CAUSE:
      SOLUTION:
      Temporary Solution:
      The machine has this firmware:
      PowerSaving Sys F.17 M0265773E
      System/Copy 2.10 M0265771S
      another idea?
      Can I disable power saving?
      • TonerMunkeh
        Professional Moron
        • 3865
        Try enabling SP5191, it stops the controller going to sleep when the machine goes into standby.
        Hit it.
        • pakobernal
          • May 2012
          • 46
          thank you very much for the idea, but it doesn't work, I've tried with 5191 at 0 and 1, it does the same thing, I send to prinnt, it receives it but it doesn't print it, I have to send the document twice for it to print it.
          • TonerMunkeh
            Professional Moron
            • 3865
            That is very odd behaviour. Is the machine set up using an IP address or a WSD port?
            Hit it.
            • pakobernal
              • May 2012
              • 46
              The machine is by ip, but I have also tried by wsd and it does the same.
              • pakobernal
                • May 2012
                • 46
                Does anyone have any other ideas?
                  • 37628
                  In the printer driver check the setting for SNMP, simple network management protocol. It has been known to cause printing problems.
                  • UNICORNico
                    • May 2018
                    • 308
                    The driver is a "Universal" version ??? or on the contrary it is the specific pcl6 driver???
                    Universal drivers often do not respond correctly.
                    Is the IP on the device fixed (static IP) or using DHCP (dynamic IP)?
                    "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
