IM3000 scanner Icon (classic and app) different defaults destinations
  • lukeh
    • Jun 2012
    • 43
    Hi all
    Can a user default the different scanner Icon's/apps to have a different default scan to folder on one icon and a scan to email as a default on the other one
    with out having user codes the user doesn't want to have to select the drop down menu to select scan to folder/destination
    • 37459
    Re: IM3000 scanner Icon (classic and app) different defaults destinations
    Unless they have drastically changed the Classic scanner function you should be able to set either folder or email as the Default for the function in User Tools.
    • davidmtupper
      • Jul 2021
      • 326
      I think he wants one to have the folder list as default and one to have the email list as the default. I believe that both apps maintain their own settings but don't hold me to that, just try it to be sure.
      • lukeh
        • Jun 2012
        • 43
        Hi all
        Thanks for the help I want both apps to maintain their own defaults but if I program either of them the defaults get changed on both tried it in use tools and in the apps themselves neither worked
          • 37459
          Originally posted by lukeh
          Hi all
          What about Classic scan and quick scan?
          • lukeh
            • Jun 2012
            • 43
            It's really a stupid request but client says it's to time consuming to have to select between scan to email and folder(like really is it) hence the reason for me asking this question but would love to know if its possible with quick scan you still need to select which option to scan to either folder or email before selecting the destination
            • Zaxxon
              • 608
              Please start you post with brand, model, problem.
              • fbkhan3
                • May 2012
                • 421
                Hi all
                one touch job.JPG kindly try ''one touch job'' is that helps.
                Regard's
