I need help
  • Needhelpbigtime
    • Oct 2022
    • 3
    I need help
    Ok so I was just hired by ricoh and I need to pass the mfp exams..I have never been good at test but have a high mechanical aptitude. I have till Wednesday to make the cut for a class in boulder Colorado. I'm currently homeless and using a friend's address and wifi. Being sent away will help me save money to get a place. But I keep failing these these test and I'm running out of time. So out of pure desperation. I'm asking if anyone in the Bergen county NJ area can help me pass them. I know it might be an issue down the line but I feel confident I can overcome those challenges when the time comes. Thank you in advance,I appreciate it.
    • 16416
    Re: I need help
    Are we talking about cheating...what are we talking about here?
      • 37533
      Re: I need help
      When did Ricoh start requiring per-admission testing prior to going to the Copier Basics instructor led class?
        • 37533
        Re: I need help
        Palisades Park in Colorado in a KOA RV park.
        • Needhelpbigtime
          • Oct 2022
          • 3
          Re: I need help
          Look I'm desperate, call it what you will. I need this job and I need this opportunity.i cannot fail and my anxiety isn't helping at all. It's a 24 hour lock out when you fail the test and the clock is ticking. If I wasn't in dire straights I would not be asking. But I don't know what else to do.
          • Needhelpbigtime
            • Oct 2022
            • 3
            Re: I need help
            I don't know, I just know I need this opportunity and I'm desperate..
            • KenB
              Geek Extraordinaire
              • Dec 2007
              • 3944
              Re: I need help
              Palisades Park is a township in Bergen County, New Jersey, where the OP appears to be.
                • 37533
                Re: I need help
                Why would someone from New Jersey be going to Boulder, Colorado for Ricoh training?
                • KenB
                  Geek Extraordinaire
                  • Dec 2007
                  • 3944
                  Re: I need help
                  I agree.
                  It smells fishy.
                  Not to be harsh, but if someone can’t pass basic tests, perhaps they’re best suited for a different profession.
                  • kingarthur
                    • 1369
                    Re: I need help
                    When you do a Konicaminolta course, you have to do a test in your own office, before doing the course, and then it a test on arrival before doing the course, which if you failed - you got sent home. So Ricoh might do the same
                    • kingarthur
                      • 1369
                      Re: I need help
                      Not necessarily so - I'm absolutely sh*t at doing written tests, I get palpitations, bad anxiety, sweats - but put me in front of a machine, with or without a manual, and I'll fix it - I've just done 44 years in the same job, so I must be doing something right
                      • kingarthur
                        • 1369
                        Re: I need help
                        Unfortunately, only you can pass the exams, I hate exams too, but always seem to pass them. I think you need to learn to control your anxiety ( says he who always has bad anxiety before and during exams). go online and try one of the many self help videos that help with anxiety etc. once relaxed, you may know more than you actually realise. Good luck.
                          • 37533
                          Re: I need help
                          If so, it has been a change in the last 4 years. Before I retired I had been going to Ricoh classes for about 20 years and never once did I have to take a test before going to an instructor lead class. Now they did give a basic technologies test the first hour of the class that you had to pass go get sent home. For awhile they did have a CBT, Computer Based Training, course on color basics that each dealership had to have at least one tech take before getting their first digital color.
                          • mojorolla
                            The Wolf
                            • 2627
                            Re: I need help
                            Sharp used to do a pre-test upon arrival, if you failed it was up to your supervisor to decide to send you home or stay in the class.
                            Nothing like getting a test first thing in the morning after spending 9 hours on the road...to New Jersey no less.....oof!
                            When I take online tests, I download all the service, parts, install, etc manuals before I start the test. You can leave these open in the background and use CTRL + F to find the terms being used in the questions. If you are asking others to do your test, probably not a good fit for you. This is not a "fake it until you make it" type of career.
                              • 37533
                              Re: I need help
                              With Ricoh a lot of the service manuals for earlier models contained a Detailed Descriptions section. A lot of the basic digital copy process could be learned from that section.
