PC600 color printer noise
  • DH1980
    • Mar 2009
    • 52
    I have two PC600 making a bad noise then jam or cram the print. Sometimes it will throw the color registration off and sometimes it just crams the print to gether.
    I have been all over this machine pulling the drums and developers. Can not find any troubles. Sometimes it goes away for a few days.
    Thanks for any help.
    • 37532
    Re: PC600 color printer noise
    Where does it jam and what is the Jam Code JXXX?
    • AMS
      • Jun 2017
      • 73
      We had this problem and it was the ITB belt.
      • DH1980
        • Mar 2009
        • 52
        The jam codes are 042. I did swap the ITB with a working machine. Hope that works.
        The noise is like gears not meshing. The noise comes and goes. I will report back after a few days.
        • DH1980
          • Mar 2009
          • 52
          It was the ITB belt. A little white bushing is oblong and causing the noise. Had to purchase the whole unit to get the bushing.
            • 37532
            Check the parts catalogs for some older models. Might use the same bushing and have a part number. One thing though, they often don't sell things like bushings, retainer clips and screws as individual items. You get a bag of 50 or 100 so pay attention to the quantity of issue when you order.
            • emiliorsg
              • Jul 2018
              • 141
              I still remember when I ordered the plastic screw for the charge corona grid of a Martini and I received a bag of 50 or more.
              • GIUBOSS
                • 1436
                I too can confirm an order for two Ricoh FT4022 spare parts: Retaining ring C, two bags of 100 pieces each have arrived!
