Ricoh Aficio 1515 bluetooth pairing pin number?
  • CopyTech1975
    • Oct 2021
    • 17
    [Misc] Ricoh Aficio 1515 bluetooth pairing pin number?
    Been searching the manuals, does anyone know the pin number for pairing the bluetooth on the Ricoh Aficio 1515? Thanks
  • davel
    • Oct 2011
    • 1107
    Re: Ricoh Aficio 1515 bluetooth pairing pin number?
    Never seen a Bluetooth unit on a Ricoh but I know they were an option on some.
    why would you want it?
      • 37529
      There was an optional Bluetooth interface for this model. If the option has been installed properly and is still operational, the pairing information should be somewhere in User Tools - System Settings - Interface settings.
      Considering that this is an eighteen year old machine the option is quite possibly bad. The Product Code for the option is G377. If you have access to rfg-esource, try searching for that.
      • CopyTech1975
        • Oct 2021
        • 17
        To print via bluetooth from a cell phone.
          • 37529
          You will be far better off getting a newer machine with a Smart Operation Panel.
          If the 1515 is already on a network that the cell phone can connect WiFi to, you should be able to use the Ricoh Printer and print by IP address. The app is free so it does not hurt to try.
          • anothertech
            • 1771
            PIN Code (Personal Identification Number).Bluetooth nodes can send a PIN code. This code identifies the node. When acomputer receives a PIN code, the computer can communicate with the node. PINcodes consist of four digits. B129/B130/B168/B169 uses the last four digits of theserial number as its PIN code. You cannot change this code.
