mp c 2011 black issue
  • Marwanalhajbi
    • Jul 2018
    • 72
    i have mp c2011 has an issue with only gray colour, it prints black normally but when i print gray it almost disappear.
    if can you notice on the attachment on calibration page you see like black colour is empty inside,
    any suggestion,
    PS: the scanner is not that shape, apologies for the scan quality,mp c2011.pdf
  • Marwanalhajbi
    • Jul 2018
    • 72
    Re: mp c 2011 black issue
    sorry nottomention,
    i have changed a new pcu and development unit,the MFP is updated and still same issue.
    • tonerhead
      • Sep 2009
      • 582
      Your laser is clean? Your sample shows all colors are not really a complete fill. I would lean towards ID sensors, itb assy, or paper transfer roller. If you do a sky shot and stop the copy, is all of the toner being transferred to paper or is some left on ITB? Is your pro-con all 1's?
      I've proved mathematics wrong. 1 + 1 doesn't always equal 2.........
      Especially when it comes to sex
      • TonerMunkeh
        Professional Moron
        • 3865
        When the black unit starts to rotate you can hear a clunk in the back of the machine when the dev solenoid activates. There's a sticky pad on that solenoid similar to the Adonis exit unit one that sticks, stopping the dev drive kicking in intermittently. Always worth a look.
        Hit it.
          • 37484
          Is the problem when printing or only when copying? The fading I see in your sample could be a scanning issue. try cleaning the optics.
          One other thing, the laser process is write to no charge. Grey scale is achieved by adjusting the laser intensity. If there is a film built up on the laser shield glass, it might cause the grey scale to taper off more than normal. It could also be a bad laser unit.
          • copier tech
            • 8144
            any suggestion,
            PS: the scanner is not that shape, apologies for the scan quality,[ATTACH]55139[/ATTACH]
            Does the black PCDU have the rear cover fitted ?
            • davel
              • Oct 2011
              • 1104
              Probably not.
