C4000 Exit Jam
  • tinfox
    • 317
    [Jamming] C4000 Exit Jam
    This is happening constantly not intermittently. I was there when it started happening and removed the jam. Nothing was torn. I gently forced some construction paper through to see if there was any obstruction. There was not.
    I removed the booklet finisher and bridge unit. Still jams. Jam code is J020 (Paper exit sensor does not detect paper)
    Here is a video
    Shared album - tinfox - Google Photos
    Any ideas? You'd think this would be obvious, but I can't figure it out. It's like the exit rollers aren't spinning, but they are.
  • DH1980
    • Mar 2009
    • 52
    Re: C4000 Exit Jam
    Here is a video
    I would try a different exit section. I have seen where the sensor can be covered in toner.
    • tinfox
      • 317
      Re: C4000 Exit Jam
      I partially lied. lol
      The last exit rollers are spinning the ones before are not at all.
      I tried to write on the photo. It may be tiny. Also its in yellow.
      I have never seen this before, like, ever. Is it a clutch or something? It was never intermittent, it just stopped. so strange...exit_rollers1.jpg
      • TonerMunkeh
        Professional Moron
        • 3865
        Re: C4000 Exit Jam
        With a box this old, if you can get an exit unit, just replace it.
        Hit it.
        • tinfox
          • 317
          Re: C4000 Exit Jam
          Had a under 50K parts box.
          replaced what were calling the exit unit. Although in my 30+ years I have not had to do this... but it IS old.
          So the gear that drives those rollers was egged out or something I don't know what is supposed to be there but it was not turning those rollers.
          all good now
          this is what i replaced.
            • 37444
            Re: C4000 Exit Jam
            I have never seen this before, like, ever. Is it a clutch or something? It was never intermittent, it just stopped. so strange...[ATTACH=CONFIG]55154[/ATTACH]
            On the roller that is not turning, these older machines are notorious for the bronze bushings in the exit section causing a lacquer, dried oil, buildup on the roller shaft after years of usage. This causes it to be hard to tune the roller which eventually stalls and rounds out the gear that drives it. That is most likely what has happened to your machine. It is often only the bushing at the rear. With luck and a can of either de-greaser or contact cleaner. you can the bushing(s) loose. Do not use WD40 as it will quickly cause more lacquer build up. Use silicon oil or fuser oil to lube the bushing(s). You may end up needing a replacement gear if it has gone too long.
            • TonerMunkeh
              Professional Moron
              • 3865
              Re: C4000 Exit Jam
              That's the bugger. Lost count of how many of those screws you had to take out of the back of it behind the fan ducting.
              Hit it.
                • 37444
                Re: C4000 Exit Jam
                I always found it easier to remove the DF and scanner in order to get at the exit section.
                • TonerMunkeh
                  Professional Moron
                  • 3865
                  Re: C4000 Exit Jam
                  Then you're a mentalist :P
                  Hit it.
