Ricoh mpc3003 Horizontal black lines or scan and copy
  • Pixtech Frameworks
    • May 2020
    • 241
    Hi All,
    Hope this posts meets we all well.
    My attention was called to a mpc3003 of the having horizontal lines on the top of the page on copy and scan, also cuts the page of copy at the top and bottom. Prints looks fine. Attached is a copy for further elaboration. Thanks all.
    • 37711
    Re: Ricoh mpc3003 Horizontal black lines or scan and copy
    That looks like scanner registration is way off
    • sandmanmac
      • 3993
      Originally posted by Pixtech Frameworks
      Hi All,
      Is this using the DF only or also when scanning/ copying from glass?
      I agree with Tim, just looks like a registration and/ or magnification.
      How does the size and registration compare to your original?
        • May 2020
        • 241
        Magnification isn't same as original, same horizontal lines on DF too .
        • GIUBOSS
          • 1443
          Sudden problem or following a move, etc .. I would double-check the scanner values ​​in the birth certificate and a firmware update wouldn't hurt.
