Ricoh MP C4502 Toner cartridge not set correctly
  • thurmmy
    • Aug 2016
    • 102
    Good morning fellow techs. Winter is arriving here in the Rockies. Now to the problem. I have a C 4502. The customer went to replace the black toner and the replacement says that it is not set correctly. The toner is genuine Ricoh, both of them. However, the one being removed has black end, says genuine Ricoh MP C3502 & MP C5502.. The one we are trying to install has brown end. The only difference that I can see is the tab at the 2 o'clock position on the black one is smaller. Both install completely. The one with the brown end I have used these for years with no issues. When reinstalling the black ended one it is fine, switch to the brown ended one, toner cartridge not set correctly. I have pulled apart the rear of machine and nothing seems to be amiss. Any ideas?
    • 36854
    Re: Ricoh MP C4502 Toner cartridge not set correctly
    Interesting. It may say Genuine Ricoh but unless you had a typo, C3502 and C5502 do not use the same toner bottle. Same recipe as they use they same developer but different amount of toner. c3002/C3502 has a yield of 28,000 print where as C4502/C5502 has a yield of 31,000.
    It may be damaged contacts either on the bottle or the toner bottles detection board.
    • sandmanmac
      • 3964
      If one works and the other one doesn't then it sounds like you are wasting your time tearing apart the machine.
      Like Tim, I'm also confused by your model numbers.
      C3002/C3502 are same
      C4502/C5502 are same
      I've been told that you can use the C3502 in the C4502/5502, but not the other way around due to the larger size, but I've not tried it myself.
      You haven't mentioned even just trying another toner cartridge. It just sounds like a bad chip
        • 36854
        Had to once or twice when the supplies clerk forgot to order before going on vacation. I also remember when the C2051/C2551 came out they were able to use C2050.C2550 color toners but not the black. bottle would not slide all the way in.
        • kleankopy
          • Feb 2016
          • 114
          The 3002/3502 will work in 4502/5502 but not other way around. The OEM 3002/3502 are black, but no model numbers are on cartridge. If the one you took out says (genuine Ricoh MP C3502 & MP C5502) it's a compatible. If the Oem toner is 4502 and says not set correctly maybe, your machine is not a 4502. Print a config page
          and verify. Maybe your new cartridge chip is defective. Swap it with used chip and see if it works.
            • 36854
            The Cxx02s did not use an RFID chip. They used a toner bottles detection board and the contacts on it and the bottles can get physically damaged if the bottles are shoved into the machine to hard. I have had to straighten a few out. See 4.14.17 TONER BOTTLE DETECTION BOARD section of the manual.
            • thurmmy
              • Aug 2016
              • 102
              Yes, I am familiar with the C3502 and C4502 differences. The bottle I took out for sure says Genuine Ricoh C3502 and C5502 on it. That is what has me confused. It works. Still has some toner left in it. The one I attempt to put in, actually have tried 2, are for sure Genuine Ricoh. I find no references to a toner cartridge that is for both. Also confusing. I did check the contacts on the PCB on rear of machine. Why would the questionable toner work and the correct toners not? And 2 of them besides. I have ordered a cartridge of a reliable aftermarket toner and will try and see what happens. I don't normally use aftermarket toner but I need to try and see what happens.
              • thurmmy
                • Aug 2016
                • 102
                Slimsob, when reviewing the S.M. on the bottle detection board, I did look at these yesterday and they looked ok. I didn't try to reform. I seems that this would be the most likely cause, but why would one work and the other not? When I go back over there I will recheck and maybe reform those contacts.
                  • 36854
                  The contacts on the bottle are usually where the problem occurs and it could be the bottle is defective.
                  • thurmmy
                    • Aug 2016
                    • 102
                    Not likely 2 new bottles would both be bad. Not impossible but unlikely. I will try a third one though.
                    • thurmmy
                      • Aug 2016
                      • 102
                      Also, thanks for your experience and help.
                        • 36854
                        Well i have had multiple bottles at the same customers with damaged contacts from the same goon trying to force them into the machine.
                        • sandmanmac
                          • 3964
                          I find this interesting. I've never heard or seen such a thing on actual Genuine Ricoh brand.
                          Can you upload a couple of pics?
                          • thurmmy
                            • Aug 2016
                            • 102
                            Will do. I think they are closed today and possibly Monday, but yes I will.
                            • thurmmy
                              • Aug 2016
                              • 102
                              I have returned to the scene of the crime today and this is what I have found. Label beneath tone cartridge tray "black toner # 842201". This relates to a C 3502 and C 3002. The Machine is labeled as MP C4502-RM. The afore mentioned toner also crosses over to 841735. Curious for sure. The aftermarket C4502 toner also did not work. What the heck kind of C4502 model is this?
