No web interface
  • iscott
    • Mar 2010
    • 344
    No web interface
    Well here's what I got
    Ricoh MP C4504ex
    You type in the ip address in a web browser and it connects shows the machine id and model in the browser tab but that's it screen stays white.
    You can hear the machine making the noises when you connect but nothing else happens.
    You can print but apparently you can't scan.
    Air Print works
    Tried
    Different IPs including dhcp
    Different browsers Chrome FireFox and edge
    This is the second machine in this location with the same results
    This machine is connected via a erros
    I have slowed down the nic card
    and swapped out the cables.
    Powered everything down and back on multiple times
    I have used every cussword's I know so if anyone has anything please let me know.
    • 37280
    Re: No web interface
    When you "Powered it down" did do a full purge the power shut down or just a control panel? What you need to do is either power it off from the control panel and leave for 2 hours before turning it back on or turn off at the control then immediately disconnect the power cord and hold the control panel button down until the power LED flashes. This discharges all the capacitors. When you power back on you will have the option of launching the full android service menu or you can just let it startup. It will also return the touch screen calibration to factor final settings in case you ever have a touch screen problem.
    If you still have problems try connecting you laptop directly to the C4504. This will eliminate all LAN cause problems.
    • iscott
      • Mar 2010
      • 344
      Have not tried a power purge......yet. I doubt that would be a solution since it did the same exact thing with 2 different machines.
        • 37280
        If they were both in the same building and it was a power surge that caused the problem. A lot of dealers think that quality power protection is too expensive until they have to replace a $500+ board.
        • iscott
          • Mar 2010
          • 344
          Sorry didn't explain that it was another machine that I brought in after I could not get the first machines interface to pull up. It was not in the building until yesterday. I really feal that is is either an issue with the Erros wifi or the Verizon hot spot. With the Erros my most likely suspect.
          • copier tech
            • 8131
            Ricoh MP C4504ex
            Air Print works
            Tried
            As you have two devices with the same issue at this site connect your laptop directly to the MPC4504 & see if you can open the WIM ok ?
            If you get the same issue update ALL the firmware.
            โ€‹
            • KeviM
              • Oct 2019
              • 324
              I concur. Connect your laptop directly and try to access the machine
              Also since it occurred with 2 different machines is the other machine in your workshop? If it is you connect it to your network and test it.
              Also try a different browser. As much as people hate Internet explorer and Edge they sometimes work well when it comes to this.
              Have you tried a firmware update? Might help
              All the best friend
              • KeviM
                • Oct 2019
                • 324
                Totally agree with you Slimslob. In areas with unstable and poor power supply I recommend clients get an AVR. It's around $100-200 but it lasts for years and can transfered to the new machines to come.
                I always tell customers, the AVR may cost $200 but if a surge blows the controller or BICU board its about $500 and above. Excluding labour
                  • 37280
                  All the best friend
                  I'm glad you both agree with what I posted in the first reply to this thread. "If you still have problems try connecting you laptop directly to the C4504. This will eliminate all LAN cause problems."
                  • copier tech
                    • 8131
                    Don't worry you can take all the glory!
                    โ€‹
