MPC2051 LCD fault
  • ozephil
    • Oct 2010
    • 6
    MPC2051 LCD fault
    Hi all,
    I have an MPC2051 which has the following problem with the LCD. All functions seem to still work OK.
    Has anyone seen this before, and if so, what fixed it?
    Thanks very much for any input, Phil
    • 37524
    Re: MPC2051 LCD fault
    I had it once. Not sure what model. First thing to try is to reload LCDC firmware in case it has been corrupted. Tech support had me clear the appropriate memory. Does it only only occur in the Copy Function? If so SP 5801-006. If everything including User Tools and SP then clear System Control Service SP 5801-003. Worse case scenario is you will have to replace the LCDC PCB.
    • davel
      • Oct 2011
      • 1107
      Probably need to find another antique machine to get panel from, good luck.
      • Gift
        • Mar 2011
        • 2459
        One might try and re-seat all flat cables and clean contacts, next step is indeed looking for a donator.
        • ozephil
          • Oct 2010
          • 6
          Thanks very much everyone, appreciate the input.
