Ricoh MP501 Cant access interface settings or service mode
  • sandmanmac
    • 3990
    #16
    Re: Ricoh MP501 Cant access interface settings or service mode
    Originally posted by engineer1234
    Have tried the 107107 clear that also doesnt work and service mode lock is disabled is there any way of checking if this software you are talking about isnt installed or any way to reset service mode login without being able to access service mode thanks.
    Not knowing exactly what is and isn't available in your User Tools menu, I will point you toward a thread that has some similarities to your situation and that I also weighed in on because I had just run up against a similar situation as the poster.
    As I state in the thread, I'm unsure if I may have been able to resolve it in a different way, because I started the memory erase process without entirely intending to, and there was no way to stop it.
    It is frustrating that the original poster if this thread didn't return to close/ update the thread.
    Possible to change factory sp mode on mpc2004ex?
