Ricoh MP501 Cant access interface settings or service mode
  • engineer1234
    • Dec 2022
    • 6
    I have a Ricoh MP501 that cant access service mode or get into interface settings there is no tab option once in system settings. I have tried factory reseting the machine and admin authentication is turned off hower options are limited as I cannot get into service mode which is usually reset 806182c any ideas anyone copies fine but would like to get it to print?
  • davidmtupper
    • Jul 2021
    • 326
    Re: Ricoh MP501 Cant access interface settings or service mode
    Try Reset, 107, hold Clear to get into service mode on this one.
      • 37641
      Someone may have changed the 6 digit SP access code.
      • sandmanmac
        • 3990
        It is the new code on this unit by default.
        The SP mode MUST be 6 digits even when changed.
        That said, I know of several occasions where Reset, 107107, CLEAR (hold) has worked.
        ...But that doesn't explain why there is no interface tab once in system settings
        I seem to remember a similar situation on a machine I was picking up for resale some time ago. I think that there was some sort of 3rd party management software installed on the unit that put extreme limitations on the system settings, and once I managed to uninstall it everything came back.
        Also.....have you checked that Service mode lock isn't enabled? You will have to turn on admin authentication, and then log in just to display the tab in System settings ( that's assuming that those tabs are even available in its current state)
          • 37641
          There is also the possibility it has to do with Administrator Settings. On older models if a specific Network Administrator was setup, it would gray out the settings on the Interface Tab, maybe it now makes the entire tab non-accessible. Another possibility is the Network Security Level. The button for it can't even be seen unless you are logged in as the proper Administrator.
          • engineer1234
            • Dec 2022
            • 6
            I hve tried this but thanks anyway
            • engineer1234
              • Dec 2022
              • 6
              Have tried the 107107 clear that also doesnt work and service mode lock is disabled is there any way of checking if this software you are talking about isnt installed or any way to reset service mode login without being able to access service mode thanks.
                • 37641
                You said that you did a Factory Reset. If that means that you can get into Factory SP mode, see if the setting for the SP access code is available there.
                • engineer1234
                  • Dec 2022
                  • 6
                  what I meant is I reset system settings to factory default by holding # and pressing system settings as I said cannot get into service mode at all.
                    • 37641
                    Your best bet then is to arraign an on site visit by your Ricoh regional support person.
                    • anothertech
                      • 1771
                      Do you know how to get into factory service mode?
                      • engineer1234
                        • Dec 2022
                        • 6
                          • 37641
                          Then I take it that you are either not a Ricoh trained technician, Ricoh has some really crappy classroom instructors, or you do not have your regional rep in your email address book.
                          • engineer1234
                            • Dec 2022
                            • 6
                            I usually work on mostly sharp machines hense why I created this post would you like to tell me how I get into that mode mode if you know so I can have a look when I get chance?
                              • 37641
                              Not in an open forum like this. Imagine that damage that an untrained person could do to a machine. If you have never had a competitor cause a problem on a machine at a major client then you have been lucky.
