MP3554sp set fusing unit corectly
  • drbing
    • Dec 2016
    • 42
    hi,just replaced original ricoh fusing sleew unit,and thermostats and what now?It say set fusing unit corectly.any advice?
    Sent from my 5028D using Tapatalk
  • sandmanmac
    • 3979
    Re: MP3554sp set fusing unit corectly
    YOU obviously caused this during the service.
    It worked before YOU took it apart, and now it doesn't.
    YOU obviously have damaged something, left something disconnected, etc.
    (there is a theme developing here....)
    Yet somehow, WE should have the answer.
    Check your work.
    • drbing
      • Dec 2016
      • 42
      thanks for the answer.but the saddest thing is that unit have 2 screw and 3 connector to remove and i servicing that model for long period,and this is first time with this problem.but again thanks.
      • davel
        • Oct 2011
        • 1094
        Check the jumper wire on one connector, you may have pulled it out.
        • fbkhan3
          • May 2012
          • 421
          Cross check the jumper wire in connector with the old one and change the pin order.
          Regard's
          • UNICORNico
            • May 2018
            • 308
            Some models require resetting the PM of the replaced units.
            "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
            • luca72
              • Oct 2017
              • 1740
              make sure you have ordered the correct spare part for that model, if the jumper is positioned differently, it means that it is for another model of the same series, it may have some limitations in power management, you can instead change the jumper manually to adapt the sleeve from a higher model, to a lower one (tested from 4054 to 2554)
              "loneliness is an invention of the white man, when we are alone we talk to everything around us, we are never alone" (Ojibwa)
              • drbing
                • Dec 2016
                • 42
                jumper on thermistor...one wire moved to the right place and fixed..
                • code_52
                  • May 2011
                  • 3
                  Hi, I had the same problem with the MP 4055 spf unit (Poland). The new original thermistor AW100174 required a jumper swap.
                  You put me on the right track. Thanks!
                  • davel
                    • Oct 2011
                    • 1094
                    I believe that the jumper only tells that it is correct part for that model, not connected to anything in fuser.
