Ricoh C2504 - Connection refused when accessing Remote Panel Operation
  • Rework
    • Apr 2022
    • 10
    Hello, I'm having trouble with Remote Panel Operation app installed on Ricoh C2504.
    When I try to access through browser connection, says Connection Refused.
    I checked the network firewall and has nothing blocking it.
    The machine has the latest versions of firmware, Java, Smart Operation Panel and Apps.
    I checked twice the Remote Panel configs and its correctly enabled.
    I uploaded a video to show what is happening (and some machine configs): https://youtu.be/KLUCax_WBq0
    *I'm trying to install embedded software on this machine - NDD Print Android (It's like Papercut MF) and the machine is unable to connect to the printserver's embedded host. Seems like the machine has some internal firewall blocking the access.
    Any ideas? Thanks in advance.
  • dalewb74
    • Feb 2018
    • 1153
    Re: Ricoh C2504 - Connection refused when accessing Remote Panel Operation
    i have never heard of any ricoh having a firewall. sounds like maybe a security setting is blocking access?
      • 37491
      Try accessing it as HTTPS instead of HTTP. Some fool may have setup a device certificate incorrectly.
      • ayeright
        • Feb 2011
        • 74
        Does this box have IP filtering?
        • Rework
          • Apr 2022
          • 10
          I didn't find any security setting that could cause this problem. What should I check?
          Ok I'm gonna try.
          When u say box, you meant the printer? If yes, so I already checked Access Control and it's disabled the IP filtering.
          • dalewb74
            • Feb 2018
            • 1153
            i was referring to security on your network. but its possible someone setup something on the copier itself. but most of that i know of requires a user code. and you didn't say anything about needing a code.
            • ayeright
              • Feb 2011
              • 74
              Yes, slang in my country.
              Did you check the device certificate as Slimslob suggested? Your video at 50 seconds shows ciphertext as priority and that needs a valid device certificate - you could try changing that option to ciphertext/cleartext as a test.
              • Rework
                • Apr 2022
                • 10
                Hi, I tried both and no success.
                I changed to cleartext and tested, no success either.
                Sorry for the late reply, this week is being very busy.
                • davidmtupper
                  • Jul 2021
                  • 326
                  Not sure if it will help, but I had to use a different network port number on a newer model. Try xxx.xxx.xxx.xxx:53080 instead of just the IP address.
                  • Rework
                    • Apr 2022
                    • 10
                    Sorry but, still no success.
                    Imgur: The magic of the Internet
                    • Rework
                      • Apr 2022
                      • 10
                      Hello mates! I'm here to tell how I solved both problems. I wiped the Android system (booting up with recovery mode), re-installed the Apps (from TSRC) and re-enabled Remote Operation.
                      It works like a charm now! Thanks everyone
