Ricoh Pro C901s bad prints
  • thodulis
    • Feb 2022
    • 3
    Hello,
    I only use this machine, and am unable to get any professional help.
    This started happening relatively suddenly. I've forced toner twice, but before I break the machine by messing around with it I wanted to see what you might think the prints linked below suggest.
    Thanks in advance
    Imgur: The magic of the Internet
    • 37739
    Re: Ricoh Pro C901s bad prints
    You might tell us what the current meter counts are and when it last had a preventive maintenance service.
    • thodulis
      • Feb 2022
      • 3
      hope this helps
      202301191525.pdf
        • 37739
        Originally posted by thodulis
        hope this helps
        [ATTACH]56414[/ATTACH]
        Everything with an asterisk (*) is past due for replacing. Most of them could be the cause of your problem.
        • thodulis
          • Feb 2022
          • 3
          I know you won't like this question, but company I work for is a bit tight on budget, so do you have any idea what I should start with, or maybe any further diagnostics I should do perform?
            • 37739
            Write an estimate to replace what is beyond PM specification, hand it to your boss and ask him if he wished to lose a customer.
            • anothertech
              • 1775
              So here's what you do. Is the problem only with black? If yes, then start swapping everything around the drum, including the drum itself, to other colors until the problem moves to the other color. Then you know what is causing the problem.
              You really are going to have to replace all of those PM parts that are overdue if you expect to get decent copy quality out of this machine.
              Also, get a humidifier if the humidity is low in there.
              • imaginemoko
                unTrusted Tech
                • Jan 2008
                • 289
                could be dirty laser target glass, due to aged developer or bad or dirty K dev magnet roller or worn out K dev entrance seal...
                fix the customer first then fix the machine... its simple and makes life more easy.
