3245 C Image quality poor in black
  • Rick
    • Mar 2007
    • 277
    The Image in black is all washed out . I tried new dev units and drum units and no difference. I suspect the developer drive clutch . If so is the clutch from a 2238 the same ? Also is there a way to do a free run on the drive clutch so I can make sure of this . Also I am getting a Independent supplier toner is set . I checked the manual and cant see where to change this.
    Any ideas anyone ?
  • bonnie750
    • 302
    sounds like the transfer release lever is not at the home position. customers force the door shut and bend the interlock to the left, this allows the front door to close while leaving the lever to the left and not upright
    • bonnie750
      • 302
      5804-19 k dev clutch check
      • Rick
        • Mar 2007
        • 277
        I checked all the other colours singually and they are ok its just the black.
        • Cipher
          It's not easy being green
          • May 2006
          • 1309
          Any ideas anyone ?
          5051-001 Toner refill detection display set to 1.
          Could also be the cause of your problem if the toner being used is not geniune OEM stock.
          • tjvincent
            • 280
            What does an internal print look like ?
            • Rick
              • Mar 2007
              • 277
              I printed off a meter count and it was still bad
              • rthonpm
                • Aug 2007
                • 2853
                Did you try cleaning the laser slit glass with the 'toothbrush'?
                • Rick
                  • Mar 2007
                  • 277
                  'toothbrush'?
                  Yes and I also cleaned the optics and the transfer belt assy.
