Ricoh MP4054 USB Print App Selection Buttons in Chinese
  • laser801
    • May 2014
    • 151
    Ok...Here's one... I have a Ricoh MP4054 That when they use the "Print from Storage Device(USB) , The selection buttons on the Smart Panel are in Chinese on the display... The Machine Language is set to English...Not sure where to change those settings to English... I checked some other machines and the App is a little different.. No biggie.. Thanks if anyone cares... Lol
  • GIUBOSS
    • 1437
    Re: Ricoh MP4054 USB Print App Selection Buttons in Chinese
    So what did you try to fix the problem
    • Tony in Oz
      • Dec 2021
      • 13
      Update Firmware ?
      • mikadonovan
        • May 2008
        • 2931
        I would completely uninstall the app, then download and reinstall it. Sounds like the wrong version of the app.
        NEVER ASSUME ANYTHING
          • 37628
          The MP 4054 should have all supported languages available for selection. As such, it might be possible for a function at initialization to select the wrong language. Try doing a full power down so as to clear the android control panel memory:
          1. turn off with the control panel power button
          2. unplug the power cord
          3. press and hold the power button until the power LED winks
          When powered back the problem might be resolved. If not, select a different machine language, see if the new language is displayed. If it is, switch back to the the language you want to use.
