MP2555 add tab to top of SOP
  • copyaction
    • Oct 2007
    • 991
  • copyaction
    • Oct 2007
    • 991
    Re: MP2555 add tab to top of SOP
    Found it!
    Under screen device settings, function key. (Looks like 3 are available)
    Have a great weekend!
      • 37533
      They are called application icons. Just as with any android, you drag them from where they are stored to where you want them. The square at the far right with the 3 rows of 4 dots is the standard icon for accessing additional applications on an android. Tap it and it should take you to the additional applications. Dots at the bottom of the screen will indicate how many pages of applications there are and highlight the one you are on.
      Ricoh used to have a program called SOP Designer Tool that simplified it for you as well as allow you to install additional applications, widgets and short cuts.
      • sandmanmac
        • 3981
        The function keys that he's referring to at the top are done differently. The buttons aren't even visible by default.
        copyaction is right that they are set / programmed using screen device settings, yes, only 3 are available.
        I always program them in a similar way myself, because most of my customers prefer the Classic Apps, and while you can obviously add the Classic Apps Icons to the home screen, there's 2 things I like about the function keys:
        1: They remain even after a user inevitably uses the "hamburger" icon (or whatever it's called) at the bottom of the screen and resets the home screen to the default Icons.
        2: You can switch between the 3 functions without going to the home screen first
        • peterxu256
          • Jul 2014
          • 110
          Could you someone give me some advice how to pop up "Function Key Settings" under Screen Device Settings. Because I don't have the tab of Function Key Settings, only have "Function Priority, Thanks
          • Leoculus
            • Jul 2024
            • 62
            you can increase the number of buttons to 5. unfortunately i wont be back in the office until after christmas to give you the settings to change
            • peterxu256
              • Jul 2014
              • 110
              Thanks so much and wish you have a wonderful Christmas holiday!
              • Leoculus
                • Jul 2024
                • 62
                in SOP service mode there is a setting for the number of function keys. can set from 3-6
