MP402 Noise
  • sandmanmac
    • 3981
    [Misc] MP402 Noise
    Hi All..
    I picked up 3 of the MP402's recently and 2 of them have the same noise when you close the front or rear cover.
    I only have a couple of others in the field, and they don 't have the noise (as far as I'm aware)
    I've done a few longer runs including duplexing - both to see if it would happen during that time, and also to see if it would work itself out.
    The noise was basically non-existent during use, although I did hear a couple of short "whines" during the run.
    Machines work flawlessly otherwise, and the meters aren't high at all.
    It's not the Toner cartridge OR the PCDU, but I can't figure out what would cause it .
    It doesn't even occur when the machine warms up out of energy saver mode - It's basically only when the front/ rear cover is opened / closed
    It's almost as if it's an inherent issue with some of these units?
    Anyone else experienced this and have a fix?
  • mikadonovan
    • May 2008
    • 2931
    Re: MP402 Noise
    If you clear a misfeed by opening the covers you mentioned, maybe it has something to do with a fuser pressure motor. Just a thought, Sandy. I have never worked on one of these.
    OR, it could have something to do with this.
    NEVER ASSUME ANYTHING
    • KeviM
      • Oct 2019
      • 324
      Re: MP402 Noise
      Thank you for the video.
      It's bit of a tricky 1 because the noise is not constant.
      I got a 402 in the workshop and it doesn't make those noises.
      I would suggest 2 things
      1) remove your fuser and check for issues. I believe there a cleaning roller on the pressure roller. Perhaps it's coated and needs to be cleaned.
      2) do an output check. SP5804 (if I'm remembering correctly otherwise it's 5803) turn on the motor for the main drive and for the fuser and the duplex. Check if 1 of those start making that noise
      All the best friend
        • 37532
        Re: MP402 Noise
        I have had a similar noise problem with previous low volume models when a film of toner builds up either the shaft of the transfer roller or the inside of the bushings. It makes the gears of the roller jump teeth with the gear on the drum that drives it. After a few seconds, the roller starts turning freely until it set for a couple of hours.
        • sandmanmac
          • 3981
          Re: MP402 Noise
          Thanks Mika!
          There's no pressure release mechanism in this unit though. The fuser just clips in much like an SP5200 if you've seen any of those?
          It's under constant pressure, but that's a good call because it does sound sort of like the main motor strains to get the fuser moving initially, but to me, that doesn't explain why it doesn't happen coming out of energy saver
          As for that bulletin. Thanks again, and I've come across that in the past, but not in this case.
          All the best friend
          There is really only the main motor output. There doesn't appear to be a fuser motor or duplex.
          I've had this issue for a while and just got around to posting about it, and I honestly can't remember if I tried another fuser from a known "quiet" machine, although I did swap in another PCDU for sure.
          This machine is at my home office. I think I have some spare fusers at my shop and will pop one in to compare when I can get to it.
          Thanks !
          • sandmanmac
            • 3981
            Re: MP402 Noise
            Just to provide a follow-up...
            I grabbed a good fuser out of an SP4520 printer at my shop to try in this unit.
            Same noise.
            I'm not going to lose any sleep over this one, since it's basically only present for a few seconds after removing a jam or changing the toner, and otherwise the printer(s) work perfectly fine
            I just thought I'd throw it out there in case someone had the remedy
            Thanks !
            • KeviM
              • Oct 2019
              • 324
              Re: MP402 Noise
              Same noise.
              Thanks !
              If you managed to resolve the issue let us know.
              Thanks friend
              • tonerhead
                • Sep 2009
                • 582
                Re: MP402 Noise
                I am thinking the cleaning roller on the pressure roller. I've had those develop a flat spot and make noise as well as causing jams. Jams and noise are primarily the first couple out after resting a while. The roller begins to re-round after warmed and using, then gets a flat again on resting. A quick test would be to simply remove it and run without. I've had a few running without that cleaning roller with no adverse effects.
                I've proved mathematics wrong. 1 + 1 doesn't always equal 2.........
                Especially when it comes to sex
                • tsbservice
                  Field tech
                  • 8020
                  Re: MP402 Noise
                  But he tried another good fuser
                  Sandy what about startup, did you hear it when you turn the machine on? Can't you cheat cover to see/hear better where the noise is coming from?
                  Otherwise it does sounds like jumping gears so slim can be right.
