Hi All..
I picked up 3 of the MP402's recently and 2 of them have the same noise when you close the front or rear cover.
I only have a couple of others in the field, and they don 't have the noise (as far as I'm aware)
I've done a few longer runs including duplexing - both to see if it would happen during that time, and also to see if it would work itself out.
The noise was basically non-existent during use, although I did hear a couple of short "whines" during the run.
Machines work flawlessly otherwise, and the meters aren't high at all.
It's not the Toner cartridge OR the PCDU, but I can't figure out what would cause it
It doesn't even occur when the machine warms up out of energy saver mode - It's basically only when the front/ rear cover is opened / closed
It's almost as if it's an inherent issue with some of these units?
Anyone else experienced this and have a fix?
