Ricoh MPC6003
  • ribatur
    • Feb 2023
    • 4
    Ricoh MPC6003
    Dear all
    I have installed a Ricoh MPC6003 but I have experienced some lags (more than 1 minutes) when I finished to print out some documents from pc and started to make some photocopies. It seems like the machine is verify or testing or performing some controls before starting a new function. Have you already had some experienced concerning this problem?
  • ridgemill
    • Sep 2017
    • 193
    Re: Ricoh MPC6003
    Do you the Data Overwrite Security enabled, or Data Overwrite Security Unit Type H / I installed?
      • 37641
      Re: Ricoh MPC6003
      Sounds like it is running Process Control (Pro Con). Check SP 3533-001 and -011 and SP 3534-001 and -011. SP 3533 will interrupt during a job. SP 3534 will interrupt at the end of a job. If the set number of page have occurred since the last Pro Con, it will run again. Default is 500. Setting to 0 will disable but may cause slight decline in image quality.
      • TonerMunkeh
        Professional Moron
        • 3865
        Re: Ricoh MPC6003
        Could also be the HDD is getting a bit tired. Try also disabling SP5730, switch the Java off.
        Hit it.
        • Oze
          Ricoh Fanboy
          • Jul 2008
          • 1663
          Re: Ricoh MPC6003
          WSD printing?
          Are you using the correct port and print driver?
          • ribatur
            • Feb 2023
            • 4
            Re: Ricoh MPC6003
            dear colleagues
            I have checked all the process control you have written as a reply to this thread and the machine now is becoming faster.
            Thank you very much
