Mottled output
  • Oscar57
    • 79
    Mottled output
    Hi,
    Would like to get some input on this copier Ricoh MP C6003 output.
    The output looks like it's not fully transferring to the paper. It's on all colors.
    I've replaced the drums and the developing units and the transfer belt assy.
    And cleaned the optics. Is there any voltage adjustments that can be made.
    Any input would be appreciated.
  • mikadonovan
    • May 2008
    • 2931
    Re: Mottled output
    Make sure the ID sensors are clean.
    NEVER ASSUME ANYTHING
    • emiliorsg
      • Jul 2018
      • 141
      Re: Mottled output
      Try to change the paper transfer roller unit.
        • 37532
        Re: Mottled output
        Considering that the C6003, is 7 to 10 years old, has the RTB assembly ever been maintained properly. If not a new belt then at least remove, wipe all debris from the inside surface and clean all the rollers.
        • Matt Sr
          • Mar 2023
          • 4
          Re: Mottled output
          That's the PTR that causes that.
          • Gift
            • Mar 2011
            • 2459
            Re: Mottled output
            How much does the quality improves if you bring, unpack and use a fresh realm of thrustworthy paper from your own shop (like color copy).
            A new PTR might also help improving things. If you perform a test print and force it to stop during paper transfer you can check the image on the ITB: It should look pretty solid before paper transfer and after paper transfer there shouldn't be too much residue left on the belt.
            And check the enviroment (temperture/humidity). I also seen machines doing this if they are placed close to an entrance/exit door to the outside.
            I guess this will be my post #2k LOL
            • TonerMunkeh
              Professional Moron
              • 3865
              Re: Mottled output
              He named that tune in one.
              Hit it.
                • 37532
                Re: Mottled output
                Are you using Genuine Ricoh toner? OEM is not Genuine. OEM suppliers do not preform the same quality controls that Ricoh does.
                • Gift
                  • Mar 2011
                  • 2459
                  Re: Mottled output
                  For a few prints he was using at least a little bit of genuine toner after replacing all dev units (if they were genuine of course)
                  • Matt Sr
                    • Mar 2023
                    • 4
                    Re: Mottled output
                    The machine would say something if they weren't.
                      • 37532
                      Re: Mottled output
                      No it won't, unless the RFID chip is corrupted and that can happen even with Genuine Ricoh.
                      Now stop making excuses and tell us if you have ever used supplies or parts that are not Genuine Ricoh.
                      And while we are at it, what is the type of paper being printed on and is the C6003 properly configured for that paper type. There are nearly 2 dozen paper types that can be specified in the C6003 PCL driver or through User Tools.
