Crossover cable
  • mikadonovan
    • May 2008
    • 2931
    Crossover cable
    Hi, All I must be having a slow brain day. I have need to hook my laptop directly to a MFP, but it has been many years since I have done this, and I do not remember the procedure. Can someone refresh my memory?
    Thanks.
    NEVER ASSUME ANYTHING
  • tsbservice
    Field tech
    • 8020
    Re: Crossover cable
    Crossover not needed anymore use normal patch cable and be happy 🙂
    • mikadonovan
      • May 2008
      • 2931
      Re: Crossover cable
      Ok, but I know I am supposed to change some IP settings on the laptop for this to work.
      • tsbservice
        Field tech
        • 8020
        Re: Crossover cable
        Yes Sir make it like for example:
        MFP: 192.168.100.5
        Laptop: 192.168.100.6
        In more simple words add 1 to copier IP address and set this as laptop IP.
        • mikadonovan
          • May 2008
          • 2931
          Re: Crossover cable
          MFP: 192.168.100.5
          That's what I was looking for. Thank you.
            • 30291
            Re: Crossover cable
            If you get a 5 port switch you don't need a crossover cable.
            Also the switch will tell you if you have a link light as some new equipment doesn't have the light
            • KenB
              Geek Extraordinaire
              • Dec 2007
              • 3944
                • 37529
                Re: Crossover cable
