Ricoh MP C6004
  • jeanpaul
    • Mar 2009
    • 117
    [Misc] Ricoh MP C6004
    Hi to all,
    i have a MP C6004 that power off 2 mins after power on.
    Can someone help?
    Thanks & Regards
    Jean Paul
  • ABS tect
    • Sep 2013
    • 511
    Re: Ricoh MP C6004
    Do you have any other information? Plugged into wall, strip, or surge protector? Sitting idle and then shuts off or when running something it shuts off. Got enough juice in your outlet? Firmware up to date?
    • anothertech
      • 1769
      Re: Ricoh MP C6004
      Print the SMC report, are there any service codes stored?
        • 37487
        Re: Ricoh MP C6004
        Try turning it on with the front door open. That will prevent the engine from starting up, If it stays on then you have something at about the 2 minute mark into the engine startup sequence that is shorting the power down. After that, start disconnecting peripherals.
