Afiicio MPC2050 Factory Reset
  • Spar
    • Jan 2019
    • 32
    I want to rest the copier to fcatory reset, I tried # and * pushed togather for 10 sec. Copier restarted but came back with no change. This method does not work.
    Please help,
  • sandmanmac
    • 3979
    Re: Afiicio MPC2050 Factory Reset
    There is not one single process to do that, and there is never legitimate reason to do so as far as I know,
    ALSO....trust me when I say that you will likely never recover the machine to proper operating condition if you did -Unless you have the 'birth certificate', because many Factory settings are NOT the settings that the machine ships with.
    So let's start with giving us some reasons for post and see where it takes us........ I'm guessing it's probably something simple
    • mrwho
      Major Asshole!
      • 4299
      Please help,
      What do you mean by "factory reset"?
      Mascan42
      Ibid
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        It had better NOT be an attempt to reset the counters.
          • 37348
          If what you are wanting to do is clear the admin password and someone has also changed the supervisor password is a sub-code of SP 5846 that is only accessible from Factory SP mode. The code to enter that is company confidential information and is not made available to those who are not a qualified Ricoh technician. It normally is shown to a dealer service manager by a regional support rep during a visit to the dealership.
          • GIUBOSS
            • 1385
            Please help,
            For what reason? What problem did you encounter?
            • Lebulck
              • Jul 2020
              • 2
              If you want to, you can reset the the user settings as follow :
              1) Press the "user tools/counter" symbol (the small button to the left of the screen) .
              2) Hold # key and press system settings.
