Ricoh MP C306 loose white toner clip
  • Will
    • Jun 2007
    • 171
    Have a Ricoh MP C306 that shows Yellow toner cartridge is out, but when replacing the cartridge noticed the white clip on the left side of the back of the toner housing is loose and not snapping back like the one on the right side of the housing.
    Can't tell from the parts manual or the service manual if the white clips are part of the toner housing or part of the toner hopper supply piece. Can somebody clarify?
  • semi
    • Sep 2008
    • 195
    Re: Ricoh MP C306 loose white toner clip
    Push it back into place with a long screwdriver
    • copier tech
      • 8176
      I agree, I usually lift the laser unit out of the way & use a long driver to pop it back into place.
      • Will
        • Jun 2007
        • 171
        Thanks guys m, I understand that, but thats not what i asked. Again are the white clips part of the toner housing or part of the individual toner hopper supply assemblies?
        • semi
          • Sep 2008
          • 195
          Whole toner housing assembly
          • Will
            • Jun 2007
            • 171
            Thank you for clarification appreciate.
