Ricoh mp6054 cooking fan is active
  • mgipa
    • May 2020
    • 49
    Ricoh mp6054 message the printing speed is now being limited because the internal cooling fan is active). The machine still works normally, when the message appears the machine stops working for a while and then runs again. Is there any way to make the device work continuously without appearing that message? thanks
  • GIUBOSS
    • 1437
    Re: Ricoh mp6054 cooking fan is active
    Is it specified which fan is active? I think it's good as far as the warning goes, obviously there's an overheating problem. The machine is well ventilated and away from touching furniture etc. Also try updating the firmware to fix any bugs.
      • 37556
      When was the Ozone (odor) filter, D2027927 DEODORIZE FILTER, replaced if ever. It is on the heat exhaust fan. When it starts to clog, the machine starts to overheat.
      • Gift
        • Mar 2011
        • 2459
        Yes, check the enviroment and if the machine has enough space to "breathe" and if all filters are OK.
        You can also check the readings of some enviromental sensors via SP.
        I think this message can also occure in lower temp / high humidity conditions.
