IM C8000
  • T911
    • Jun 2007
    • 628
    IM C8000
    I can't get the f----n front door open to access the fuser, transfer and reg area. Is there a secret to this or am i missing something. Never had this problem b4. How is the client supposed to take a jam out. Thanks
    • 36746
    Re: IM C8000
    The only front door is the one you open for changing toner. To access the paper path you have to pull OUT the drawer. If the drawer unit will not pull out you may have a failure in the drawer unit lock, often caused by turning off while in cycle, drawer unit lock is there to prevent opening the drawer while paper is running through it. Procedure is fully covered in the service manual.
    • Daniel_B81
      • Jan 2019
      • 38
      Re: IM C8000
      Like Slimslob said, but could start with the obvious that i bet is far too easy to miss if new to these machines, if it is the same as Pro C5200 you have to open the lower left door where the waste unit is located, there is a button there that needs to be pressed to be able to open the front drawer.
      • davel
        • Oct 2011
        • 1077
        Re: IM C8000
        • Gift
          • Mar 2011
          • 2444
          Re: IM C8000
          Yes there is a "failsafe procedure" if the locking machanism refuses to open / I saw it years ago with a Pro Cxxx and it's probably explained in the SM / I can't recall the exact steps anymore.
          • T911
            • Jun 2007
            • 628
            Re: IM C8000
            Great thanks guys. I did press that button in the waste arra and it worked.
              • 36746
              Re: IM C8000
              Was the jam you needed to remove caused by some type of power failure? That could cause the engine to halt immediately with the some component not in its home position.
              • T911
                • Jun 2007
                • 628
                Re: IM C8000
                No idea wasn't at the location when it happened. No mention of power failure
                • Babujoseph
                  • 35
                  Re: IM C8000
                  Great
