Ricoh SP C250sf - Error code SC396
  • barakm
    • Jan 2023
    • 24
    [Error Code] Ricoh SP C250sf - Error code SC396
    Ricoh SP C250SF black drum gear - YouTube)
    I'm puzzled here... is the gear broken or is it the expected behavior?
    Any idea on how to proceed?
    Thanks in advance,
    - Barak
  • davel
    • Oct 2011
    • 1104
    Re: Ricoh SP C250sf - Error code SC396
    How many prints on the black unit, it is probably seized.
      • 37489
      Thanks in advance,
      - Barak
      I have never had a motor lock be anything other than excessive load. That means something that the motor drives has becomes hard to turn. What does that motor drive? oh that is right, the black PCU. Do what davel suggested.
      • barakm
        • Jan 2023
        • 24
        Guys, you are awesome! thank you very much !
        I took out the black toner, and indeed - the drum was stuck!
        I couldn't even force it to turn (I don't understand how the motor succeeded, since it WAS turning - I saw it with my own eyes).
        Anyway, I inserted a new black cartridge, and the printer is alive again !
        Thank you, thank you, thank you !!!
        - Barak
