Ricoh Pro c5100s Error 548 Fuser now J001
  • stuinthecity
    • May 2023
    • 4
    After getting a S548 Fuser error I took out the fuser inspected everything and checked online where I saw a suggestion to reset the warning. I reset the error and immediately got a phantom paper jam error located on the transfer tray right under the fuser. Thoughts?
    • 37488
    Re: Ricoh Pro c5100s Error 548 Fuser now J001
    J001 is a Jam found at restart. In other words paper that stopped somewhere in the machine when the fusing error occurred. You need to check the entire paper path.
