Two readers in SOP screen IMC range
  • huberto233
    • Nov 2008
    • 40
    Hi
    Have you ever worked on a project where you were asked to connect two different readers to new SOP panels? The concept involves integrating an already operational Mifare reader while also incorporating a biometric reader . I asked customer to get VID/PID configured just in case. Furthermore, there is Papercut software installed, which previously functioned with Java embedded. However, due to Ricoh discontinuing Java support, all operations must now be performed via SOP, and the readers need to be connected directly to the panel (previously connected to the controller).
    So Mifare works no issue but customer struggles to get biometric which simply just works as USB keyboard device
    It is IM C range IM C400 to be precise but other devices on site too
    Many thanks for any answers
    T.
    Network+,
  • dalewb74
    • Feb 2018
    • 1125
    Re: Two readers in SOP screen IMC range
    IMC is ricohs new product line. ricoh tech support should be able to help you with the issues. as i stated, they SHOULD, but no guarantees...
    • Sashko
      • Oct 2009
      • 110
      I'm not sure that is possible to use two card readers on one SOP simultaneuosly.
      • TonerMunkeh
        Professional Moron
        • 3865
        You can still order Java cards for the IMC400, I've got a shitload on order. If it makes life any easier for you, do it that way. D3GF5032.
        Hit it.
          • 36880
          If your dealership has potential sales depending being able to offer this feature, contact sales support. If enough machines are involved, they will have engineering write a Custom firmware.
