Pro 5200 Printer error Message(Fiery)
  • semi
    • Sep 2008
    • 195
    [Error Code] Pro 5200 Printer error Message(Fiery)
    Hi customer has set up device with E44b Fiery-there getting "Invalid media type was specified Press reset to cancel the job" when trying to print. Have advised to check device tray settings match the print driver-which they told me the correct driver driver is been used & the trays match.Anything else before I head over to chech the settings?
  • Imprestik
    • Aug 2012
    • 297
    Re: Pro 5200 Printer error Message(Fiery)
    Is the fiery correctly patched in the required sequence?
    Had a lot of this issue on various Ricoh production devices. Patches usually resolve the issue
      • 37532
      "Invalid media type was specified Press reset to cancel the job"generally means that the paper requested was not in the media library. It could be the paper type, thickness, color or anything else about the paper. Patching the Fiery Imprestik suggested will update/repair the media library. After that if the customer has some strange media type, they may have to manually ad it to the library.
      • semi
        • Sep 2008
        • 195
        Re: Pro 5200 Printer error Message(Fiery)-Fixed
        Customer was using E-44 PLC6 Driver instead of PS driver-thanks all
        • dalewb74
          • Feb 2018
          • 1157
          if you don't know. ricoh has a device that you can scan the paper and the add it that way into the media library. this option was available for the pro c5200. though due to the age of the copier im not certain if it is still available. that model has been discontinued.
