Ricoh SP C821DN with SC398
  • patterson70
    • May 2010
    • 599
    Hello is this SC398 a code for a particular drum? I can't find out if it is the black or one or more of the colors.
    • 37488
    Re: Ricoh SP C821DN with SC398
    From Goose's Guide
    Cyan Drum/Dev motor error - check for mechanical binds
    Cyan Drum/Dev motor error - check for 24vdc to motor
    Cyan Drum/Dev motor error - replace motor
    • patterson70
      • May 2010
      • 599
      From Goose's Guide
      Thank you very much. I will check on the Cyan Drum and see if that is the issue. Have you ever had to replace a motor on one of these?
        • 37488
        Usually only if there is a bind in either the PCU or DVU that has caused it to fail.
